| Roland_89 | Adatlap | 109821 | 2008. június 10. 14:45 | ![]() | |||||||||||||||||||||||
| Amatõr | Adatlap | 109820 | 2008. június 10. 14:24 | ![]() | |||||||||||||||||||||||
Üdv! A DAF XT 105 Torpedo -ról ennyit lehet tudni: (angolosok előnyben) " Behold...Daf's new bonneted flagship tractor---and it's 'exclusive' to Biglorryblog. Err...well almost. As ever I'm grateful to one of my regular 'cloggie' mates for an unusual picture and this one has come from Tim de Jong who tells me: "One for your blog, this photoshopped DAF XT 105 torpedo. What ARE the Dutch up to? I wouldn't know, but it won't be conquering the States with this beauty and blowing away Paccar's hometeam consisiting of Peterbilt and Kenworth. Pity really. Anyway, this does look good, don't you think?" To which BLB replies you bet and I wouldn't mind betting that Paccar will be giving your ace photoshopper a call and asking: 'How did you do that..?' Tim adds: "Imagine the new 560hp MX-engine, which is pretty late in coming, but which will certainly find its place under this good looking bonnet. The Super Space Cab roof makes it look even better, especially with the typical toplights." A perfect 'What-if' if I ever saw one." | |||||||||||||||||||||||||||
| Roland_89 | Adatlap | 109819 | 2008. június 10. 12:15 | ![]() | |||||||||||||||||||||||
| Kusti | Adatlap | 109818 | 2008. június 10. 11:00 | ![]() | |||||||||||||||||||||||
Roland! Egyáltalán nem biztos hogy Photoshop-os kép. Lehet hogy valaki rendelésre gyártatta le, nem kevés pénzért persze, szóval lehet hogy ez van élőben is legferljebb ez az egy. Kusti | |||||||||||||||||||||||||||
| Kusti | Adatlap | 109817 | 2008. június 10. 10:54 | ![]() | |||||||||||||||||||||||
| Amatõr | Adatlap | 109816 | 2008. június 10. 08:57 | ![]() | |||||||||||||||||||||||
| Kislõcsös | Adatlap | 109815 | 2008. június 9. 21:35 | ![]() | |||||||||||||||||||||||
| Salieri | Adatlap | 109814 | 2008. június 9. 21:11 | ![]() | |||||||||||||||||||||||
Ilyenen én is utaztam már:)tök kafa:) | |||||||||||||||||||||||||||
| Fodi | Adatlap | 109812 | 2008. június 9. 20:56 | ![]() | |||||||||||||||||||||||
Engem inkább az érdekelne, hogyan is kerültél fel eme szerkezetre... :) | |||||||||||||||||||||||||||
| Mekett | Adatlap | 109811 | 2008. június 9. 20:55 | ![]() | |||||||||||||||||||||||
| Gabi | Adatlap | 109810 | 2008. június 9. 19:55 | ![]() | |||||||||||||||||||||||
Sziasztok! Köszi mindenkinek! Roland! Ismerem a plató dolgot, gondolkodtam is rajta anno, de nem lesz rajta. Gabi | |||||||||||||||||||||||||||
| dini27 | Adatlap | 109809 | 2008. június 9. 19:05 | ![]() | |||||||||||||||||||||||
Sziasztok kinek van kamionra való gumiabroncsa? | |||||||||||||||||||||||||||
| Erno-945 | Adatlap | 109808 | 2008. június 9. 17:22 | ![]() | |||||||||||||||||||||||
Szia Amatőr! 1.4-es csavarhúzóra drótot tekerek,majd lehúzom.Ezek után kettévágom az egész sort,az így kapott karikákat csipesszel összeillesztem,ezeket ragasztom a ponyvára. Kis szemű láncot fogok ezek után,a szemeket 1/3-nál elvágom.Így lesz két "C"betű.A maradék 2/3-ot beleragasztom a már ponyván megragadt kerek szemekbe. A lefűző zsineg horgászdamil. 945 | |||||||||||||||||||||||||||
| tuning | Adatlap | 109807 | 2008. június 9. 17:10 | ![]() | |||||||||||||||||||||||
| rico | Adatlap | 109806 | 2008. június 9. 14:27 | ![]() | |||||||||||||||||||||||
Szia Roland! Én úgy hallottam, hogy Photoshop. | |||||||||||||||||||||||||||
| Roland_89 | Adatlap | 109805 | 2008. június 9. 14:16 | ![]() | |||||||||||||||||||||||
Simka ezt a DAF csöröst már én is megtaláltam egyszer, de aztán soha semmi más kép róla... Ezt most valóban gyártják vagy csak valakinek jó képszerkesztője van? Tud erről valaki valamit? | |||||||||||||||||||||||||||
| Kusti | Adatlap | 109804 | 2008. június 9. 14:15 | ![]() | |||||||||||||||||||||||
Szia Csetuka! Csak rácsozva lesz, nem lesz nyitható. Üdv! Kusti | |||||||||||||||||||||||||||
| Tomi | Adatlap | 109803 | 2008. június 9. 14:04 | ![]() | |||||||||||||||||||||||
sziasztok 3300 as vagy 3600 as dafja van valakinek eladó? | |||||||||||||||||||||||||||
| kemszi | Adatlap | 109802 | 2008. június 9. 13:46 | ![]() | |||||||||||||||||||||||
de nem lesz gond a méretarányok eltérése? | |||||||||||||||||||||||||||
| Simka | Adatlap | 109801 | 2008. június 9. 13:25 | ![]() | |||||||||||||||||||||||
Szia Kemszi! Tudtommal Italerinek nincs autószállító trélere, csak Revell gyárt, viszont van többfajta is, annyit tudsz csinálni, hogy átépíted eu-sra... Érdekességek DAFBÓL... Különösen a csőrös 105-ös, a 3300-asból meg volt ilyen Italeri féle élőben is Simka | |||||||||||||||||||||||||||
| Nagytalpú | Adatlap | 109800 | 2008. június 9. 11:45 | ![]() | |||||||||||||||||||||||
| Amatõr | Adatlap | 109799 | 2008. június 9. 09:19 | ![]() | |||||||||||||||||||||||
Üdv! Egy kis segítséget szeretnék kérni. Ponyva lefűző füleket miből, hogyan tudnék készíteni Köszi előre is. Amatőr | |||||||||||||||||||||||||||
| kemszi | Adatlap | 109798 | 2008. június 8. 22:59 | ![]() | |||||||||||||||||||||||
ebben esetleg tudna valaki segíteni? | |||||||||||||||||||||||||||
| Roland_89 | Adatlap | 109797 | 2008. június 8. 22:15 | ![]() | |||||||||||||||||||||||
Hali! Holnap vizsgázok, aztán a héten tanulok mert 16-17-18.án lesznek a szóbelik, utána boltolunk! :) És akkor nekiállok az MAN-nek is! HA lesz HydriDrive-os akkor fotózok! | |||||||||||||||||||||||||||
| csetuka | Adatlap | 109796 | 2008. június 8. 22:03 | ![]() | |||||||||||||||||||||||
Szia Roland! Ha mész Man-eket fotózni, csinálhatnál pár képet HydriDrive-os első felfüggesztésről, ha tudsz! Nem nagyon találtam róla normális képet. Darut mikor boltoljuk el? Kusti! jól néz ki az alváz. Homlokfalat nyithatóra szeretnéd megcsinálni, vagy rácsozni akarod? Gabi! nagy gratula a Titánhoz, mutatós darab lett... csetuka | |||||||||||||||||||||||||||
| Simka | Adatlap | 109795 | 2008. június 8. 21:44 | ![]() | |||||||||||||||||||||||
Sziasztok! Gabi nagyon állat a vas, gratulálok! Kusti "komolyodik" a Scan is ! Roland, nekem a lakókocsis Rába volt, aztán átfestettem, aztán haverom 5 éves unokaöccsénél landolt... Simka | |||||||||||||||||||||||||||
| pulcsi | Adatlap | 109794 | 2008. június 8. 21:14 | ![]() | |||||||||||||||||||||||
Sziasztok!Italeri féle Steyrt épitek,aminek az összeépitési utmutatoja szerint narancs szinünek kellene lennije.MAN F2000-es motorja az fekete.Lehet hogy ennek is annak kellene lennie?Segitsetek légyszives.Karcsi | |||||||||||||||||||||||||||
| Roland_89 | Adatlap | 109793 | 2008. június 8. 20:44 | ![]() | |||||||||||||||||||||||
| Kusti | Adatlap | 109792 | 2008. június 8. 20:34 | ![]() | |||||||||||||||||||||||
| Salieri | Adatlap | 109791 | 2008. június 8. 20:27 | ![]() | |||||||||||||||||||||||
Topline-s lesz? | |||||||||||||||||||||||||||
| Roland_89 | Adatlap | 109790 | 2008. június 8. 20:11 | ![]() | |||||||||||||||||||||||
Simka nekem a Postás és a Konténeres Rába van/volt, mert mikor megörököltem már kopottak voltak, és unokatesóm akkor megcsinálta.. lefestette nekem őket, és a egyik konténer elveszett.. a másikat lefestette, de hogy ne legyen üres a plató, csinált rá rönkszállító elemet... és kiskoromban azzal hordtam a szines ceruzákat! :) Ugyhogy a színekben már nem lesznek eredetiek... | |||||||||||||||||||||||||||
| Roland_89 | Adatlap | 109789 | 2008. június 8. 20:06 | ![]() | |||||||||||||||||||||||
Gabi! :) ha már ötlet akkor nekem lenne egy hozzá! Az ilyen erőgépeknek szokott olyan rárakható platója lenni ha a másik vonószemet használja... egyolyat érdemes lenne rá szerintem, és akkor nem kell a trailer hozzá. De amúgy nagyon fazon jó lett a gép! Mint a többi! :) | |||||||||||||||||||||||||||
| dini27 | Adatlap | 109788 | 2008. június 8. 18:43 | ![]() | |||||||||||||||||||||||
Sziasztok szép munkák készülnek próballak titeket utánozni, na mondjuk a magam 14 évével, hát még gyakorolni kell na mindegy a segítság tárgya az lenne, hogy ki tud Magyarországon pótkocsit egy 80-as évek beli kamion mögé? | |||||||||||||||||||||||||||
| Kusti | Adatlap | 109787 | 2008. június 8. 16:41 | ![]() | |||||||||||||||||||||||
Szia Simka! Nekem is van egy original, Konténeres, egy vaj színű Rábucival. Kusti | |||||||||||||||||||||||||||
| Kusti | Adatlap | 109786 | 2008. június 8. 16:39 | ![]() | |||||||||||||||||||||||
| Gabi | Adatlap | 109785 | 2008. június 8. 15:41 | ![]() | |||||||||||||||||||||||
Sziasztok! Na most gondolom úgy, hogy készen van a Titan, bárha valakinek van még javaslata szívesen fogadom. Jó volt építeni, nagyon megfogott a téma, várható lesz tőlem ebből az időszakból néhány további nehézvontató, tervek már megvannak. Gabi | |||||||||||||||||||||||||||
| Simka | Adatlap | 109784 | 2008. június 7. 23:05 | ![]() | |||||||||||||||||||||||
| Roland_89 | Adatlap | 109783 | 2008. június 7. 20:44 | ![]() | |||||||||||||||||||||||
tényleg, ha tudna esetleg valaki képpel szolgálni ehhez a játék rábához hogy nézet ki újonnan, vagy az eredeti kamion hogy is néz ki... azt megköszönöm! | |||||||||||||||||||||||||||
| Roland_89 | Adatlap | 109782 | 2008. június 7. 20:43 | ![]() | |||||||||||||||||||||||
én is láttam múlthéten egy rábát! le is fotóztam direkt itt a rába fanokra gondolva... holnap megkeresem a képeket! és a legjobb hogy megtaláltam a múltkor említésbe hozott rába játékokat. azokat is lefotózom, aztán amjd ha lesz időm felújítom őket... | |||||||||||||||||||||||||||
| vadgergo | Adatlap | 109781 | 2008. június 7. 20:40 | ![]() | |||||||||||||||||||||||
Sajnos nem, de bánom.. :-( | |||||||||||||||||||||||||||
| Simka | Adatlap | 109780 | 2008. június 7. 20:36 | ![]() | |||||||||||||||||||||||
| vadgergo | Adatlap | 109779 | 2008. június 7. 20:19 | ![]() | |||||||||||||||||||||||
Huh, debrecenben az egyetemnél láttam egy Rába Turbót lemattult szürkében, kirázott a hideg,annyira disznó volt! | |||||||||||||||||||||||||||
| Tomi | Adatlap | 109778 | 2008. június 7. 16:53 | ![]() | |||||||||||||||||||||||
Sziasztok érdeklődnék hogy nincs e valakinek eladó DAF 3600 as kamionja? | |||||||||||||||||||||||||||
| Kusti | Adatlap | 109777 | 2008. június 7. 10:07 | ![]() | |||||||||||||||||||||||
| Kusti | Adatlap | 109776 | 2008. június 7. 10:07 | ![]() | |||||||||||||||||||||||
Kumancs! Ne add fel, lehet hogy valakinél elfekvőben egy. Nemrég Atinek volt egy itt árulta, lehet hogy tud még szerezni egyet. Kusti | |||||||||||||||||||||||||||
| Kumancs | Adatlap | 109774 | 2008. június 6. 23:02 | ![]() | |||||||||||||||||||||||
Hát kösz de Ebay és haasonlókkal nem boldogulok. Igy ha majd felbukkan egy lecsapok rá. Vagy ha ujra kiadják. | |||||||||||||||||||||||||||
| csetuka | Adatlap | 109773 | 2008. június 6. 22:40 | ![]() | |||||||||||||||||||||||
| csetuka | Adatlap | 109772 | 2008. június 6. 22:38 | ![]() | |||||||||||||||||||||||
Szia Talpi! Én ugyan csak cserébe kerestem, de ha van jöhet! csetuka | |||||||||||||||||||||||||||
| Simka | Adatlap | 109771 | 2008. június 6. 22:24 | ![]() | |||||||||||||||||||||||
Sziasztok! Képek a kamrából... Most hagytam abba, fülke alapozva, első futómű is elkészült, még kábelezés hátra van elöl+ugye motor. Meg gondolkozom lehet, hogy erős a szürke, úgyhogy világosítani kell.. Talpi, kösz a biztatást! Majd utánanézek egy fekete hangszóróért, hogy mi van belül a fehérben meg az ezüstben..:) Roland, látom merész "kis kölök" vagy! Csak vigyázz, nehogy belefuss valaki olyanba, aki nem áll arébb:), az ilyen kopasz csávók nem mindig ilyen engedékenyek:) Dini, asszem volt valahol vörös rák képem, ha rábukkanok felteszem! | |||||||||||||||||||||||||||
| Roland_89 | Adatlap | 109769 | 2008. június 6. 21:43 | ![]() | |||||||||||||||||||||||
Köszönöm Gabi! Délután arra gondoltam hogy a Győri MAN képviseletben vannak ismerőseim.. majd érettségi után benézek és kattintok pár képet. Addig ha esetleg valakinek kell valamilyen részletfotó valamilyen MANről, szóljon és ha tudok akkor csinálok. De azért ezek is nagyon jók, köszi Gabi! | |||||||||||||||||||||||||||
A konténeres szerelvényben a MAN kitt nem egyezik a szolo MAN kittel.
Mi a különbség? a szoloban a kerekek színe fehér... a szerelvényben szürke :D
Szóval Italeri nem hazuttola meg magát :D ugyanaz... :D
