Makettek rendelése
sza.sa 152055 2011. november 28. 13:38
Eduard maketteket itthon kitől lehetne venni? (Mosonmagyaróvárt kivéve..)
ZétaZoll 152054 2011. november 27. 16:42
Van valakinek tapasztalata a lengyel Martola model shopról? )(www.martola.com.pl/en) Érdemes tőlük rendelni?
unicellular 152053 2011. november 25. 13:36
Egy Hannats-rendelésbe én is beszállnék. Kb. 14 GBP értékben.
mookush [kukac] gmail [pont] com
Israti71 152052 2011. november 24. 21:28
Urak! A Hannants-tól rendel mostanában valaki? Társulnék egy 7 Eurós szett erejéig. Üdv: D.A
HUJBI 152051 2011. november 23. 20:31
a surface olcsóbb a lent ismertetett okok miatt:
Surface mail is a mail delivery system in which mail or packages travel over the surface of the earth, as opposed to traveling via airplane. It may include shipping by truck, train, or boat. Most companies and governments that offer international shipping have both a ground service and air service. The advantage of surface mail is that it tends to be less expensive than air-carried deliveries, but this depends on the location the package is being shipped to. The main disadvantage is that it takes longer for your package to reach its destination.
There are many reasons why surface mail is often less expensive than air mail. The vehicles that transport surface mail, such as trucks, cost less to operate and maintain than airplanes. It may also be less expensive because most mail is transported this way. Regular transportation routes and schedules are well-established and often automated for maximum efficiency in moving mass quantities of mail. Because of this, the cost-per-piece is generally lower than mail transported by air, which sometimes requires more labor-intensive handling procedures.
ms07 152050 2011. november 23. 20:30
From Hasegawa-t írnak. A sárga F-2-es és a Draken elég jól néz ki, a Raptor és az A-10 az eléggé érdekes :D
vlevi 152049 2011. november 23. 20:15
Az hlj-n viszont elég jó akciók vannak. Kár, hogy a japán jen (is) ilyen baromi erős a forinthoz képest :(
www.hlj.com/scripts/hljlist
A rózsaszín F-22 azért kicsit erős :D
De a kék F-15E se kutya...
www.hlj.com/product/HSGSP269
Amit nem sikerült kideríteni, az az, hogy miféle makettek vannak a matrica mellé csomagolva. Mert mintha valahol Italerit is olvastam volna, talán a Hobby Search-ön.
vlevi 152048 2011. november 23. 20:11
ms07 152047 2011. november 23. 19:52
Japánoknál láttam, hogy harci gépeket lefestenek hozzá nem illő színre, és felmatricázzák anime figurákkal. Jön a karácsony, úgy volt, hogy barátnőmnek csinálok egy díszfestésű Tornádót, de megtalálta ezeket az animés képeket. Kérdés: ilyen matricát tudok valahonnan rendelni, vagy csak amkettel együtt? (Hlj-n láttam így)
landijozsef 152046 2011. november 23. 18:21
lucky 152045 2011. november 23. 18:13
landijozsef 152044 2011. november 23. 16:29
SZiasztok!Remélem tudtok egy kérdésben segíteni nekem. Ha a jadarhobby. pl oldalról szeretne valaki rendelni, akkor szállitásnál melyiket érdemes választani a két lehetőség közül a Surface mail Shipping vagy a Air Mail Shipping-t? A surface-nál a posta szállitja ki a csomagot? Előre is köszi a segítségeteket. Üdv!
Monty 152043 2011. november 23. 13:49
Villámgyors! :)
Nekem se veszett még el egy sem!
adamb 152041 2011. november 23. 13:13
HUJBI 152040 2011. november 23. 12:18
na igen, ezt szoktam leírni úgy havonta kétszer. :)
adamb 152039 2011. november 23. 09:42
közérdekű infó a vámmentességről
posta.hu/object.761F7A48-232A-494D-AA71-49A765A12F86.ivy
Atesz 152038 2011. november 23. 08:53
Szia, nekem már jött ezzel a módszerrel legalább 8 küldeményem, egy se veszett el.
8/8, szerintem jó arány!
Atesz
Zolko 152037 2011. november 23. 08:26
mi a tapasztalatotok a USPS Priority Mail-ről? Mennyire megbízható, hogy nem hagyják el a cuccost?
Zolko
ponty 152036 2011. november 19. 22:06
Sziasztok a Zenn Modelsport honlapról mi a véleményetek? Én rendeltem tőlük egy festékszórót, körülbelül hat hete, de még nem jött meg. Azt értem, hogy kellett idő mire beszerzik, de egy hete küldték, meg az üzenetet, hogy átvették a csomagot.
HUJBI 152035 2011. november 19. 11:37
a DHL oldalán airway bill szám alapján is lehet keresni pölö.
Grifx 152034 2011. november 19. 10:22
Köszönöm szépen a gyors választ!
Zsóti 152033 2011. november 19. 10:16
Én rendeltem már tőlük, viszont nem minden van nekik készleten ami fent van a webshopban, és kb 3 hónap alatt jött meg a csomag, addigra szedte össze a hiányzó dolgokat! Benne volt minden, szépen be volt csomagolva, azzal nem volt baj. Nekem ez a tapasztalatom!
Üdv: H. Zsolt
Grifx 152032 2011. november 19. 10:14
Link:
http://www.tracks-n-troops.eu/shop/index.php?main_page=product_info&cPath=7&products_id=8394&zenid=tfte6orecdaq9iaces9v480697
Grifx 152031 2011. november 19. 10:13
Igaz nem makett de hozzá tartozik…
Valaki rendelt már innen?
Ez a könyv PDF vagy rendes könyv?
HUJBI 152030 2011. november 19. 08:49
szia!
szerintem a (f)eladónál érdeklődj elsősorban, hogy mikor, hova és kinek küldte el.
ezt követően tájékoztatást adni ragszám alapján tudnak a postán vagy a vámnál.
és igen, amerikaiaknál figyelni kell, mert legtöbbször tényleg csak az államokon belül küldözgetnek, Te meg utalsz és hiába vársz.
Lali 152029 2011. november 18. 16:28
Remélem nem lopták el, fontos lenne, hogy megérkezzen. Mondjuk még az általad feladott csomag sem érkezett meg nekem, az is lehet, hogy a Magyar Posta ennyire sz@r és lassú!
Nagykövet 152028 2011. november 18. 16:10
Köszönöm a segítséget.
Nagykövet
Altengernagy 152027 2011. november 18. 15:54
Még 45 napon belül kérd vissza az árát a Paypalon... ne lépd túl. Sajnos a 1st class mail-ek nincsenek ajánlva, csak USA határig, itthon ellophatják nyugodtan.
Nagykövet 152026 2011. november 18. 15:22
Szia Hujbi!
Légi fuvarlevélszám alapján milyen lehetőségeim vannak csomag keresésére?
Előre is köszönöm a választ
Nagykövet
zkalos 152025 2011. november 18. 13:04
Nézd meg, hogy nem volt-e a szállítási feltételeknél, hogy csak az USA-n belül postázza ki ! Sajnos én úgy láttam, a legtöbb Államok béli viszonteladó csak belföldre postáz ki. Javítsatok ki, ha nem így van, de amiket én néztem ott, az mind ilyen volt sajnos.
Lali 152024 2011. november 18. 12:16
Nem tudom kinek mi a tapasztalata az ebay-es rendelésekről, de én kezdek elszomorodni. 1 hónapja rendeltem 2 készletet egy amerikaitól, és még mindig nem érkeztek meg! Lehet, hogy a fináncok nem engedték még tovább?
üdv,
Lali
HUJBI 152023 2011. november 17. 09:31
status: összeraktuk, szép lett. :)))
Monty 152022 2011. november 17. 07:53
Na, végre az enyém is vámkezelve státuszba lépett. :)
juge75 152021 2011. november 17. 06:02
Csak nehogy a következő üzenet ez legyen: Küldemény sorsa ismeretlen! :-)
Jimbow 152020 2011. november 16. 23:42
"2011.11.16 08:42 Budapest 1005 Bejövő küldemény vámkezelve / Inbound item customs procedure"
El se hiszem! Persze ezt is csak 12 óra késéssel írta ki a rendszer, de mindegy, holnap remélem itt lesz :)
Vargapeter 152019 2011. november 16. 20:53
Igaz, rögtön máshogy néznek ki az árak ebay-n!
Úgyhogy én is készülök a nagy böjtre, ami az elkövetkező hónapokra várható! :(
Monty 152018 2011. november 16. 20:22
Nekem még mindig azt írja, hogy vám előtt van. Áhh, ez hihetetlen. :(
Ezen kívül van egy amerikai, egy ausztrál és egy Hong-Kong-i rendelésem. Kíváncsi vagyok melyik lesz a befutó. Elvileg egyszerre indultak a versenyen. :)
Gordon 152017 2011. november 16. 16:19
Megjött az utolsó tétel is szintén nov. 5 -i feladással. Elég kiszámíthatatlan, de a lényeg, hogy megvan.
Altengernagy 152015 2011. november 16. 10:55
Szerintem ilyen forintnál a világon semmit sem érdemes rendelni... kivéve ha valaki reggelente kávé-cigi után pénzt szül.. :)
Jimbow 152014 2011. november 15. 22:23
HKD 30 Forint...
Altengernagy 152013 2011. november 15. 16:29
Hát a Zvezda készlete... Nekem azt mondták odakint már van, mutattak képeket is... mivel én harckocsikkal nem foglalkozom igazából (csak ha valaki kéri) így nem is kételkedtem/foglalkoztam vele komolyabban.
Monty 152011 2011. november 15. 14:34
Nálam az a furcsa helyzet állt elő, hogy a nov. 5.-én feladott no trackingos csomagom ma megérkezett, míg az okt. 26.-án feladott trackingos még mindig nem. Mindkettő lucky.
Na erre varjunk gombot! :)
Jimbow 152010 2011. november 15. 14:27
De jó neked! :)
Én már ott tartok, hogy több időbe telik a Budapest-Budapest táv, mint a Hongkong-Budapest...
Jimbow 152009 2011. november 15. 14:08
Szia bigboy!
Elvileg nem jelent még meg, a neten is csak prototípusok keringenek. És azt mondták, hogy 5690-ért odaadják ha megjelenik majd?
bigboy 152008 2011. november 15. 13:48
Üdv, én már vásároltam tőlük.Gyorsak és korrektek voltak.Egy kis ,malőrt kivéve .Augusztusban rendeltem tőlük egy Zvezda T-90 est.Szeptemberi szállítást,garantáltak,november közepe van.Így ,vagy nem jelent meg ,vagy tévedtem velük kapcsolatban.Üdv bigboy
Gordon 152007 2011. november 15. 13:21
Ma végre megérkezett a várva várt csomag! Majdnem 3 hét kellett neki, gondolom ami ez után jön se érdemes hamarabb várni.
Jó makettezést mindenkinek!
unicellular 152006 2011. november 15. 09:52
Jimbow!
Nézd meg a "Boltok" topic-ban a 1909-es hozzászólásomat. Napokig húzódott az ügyintézés, mert nem lehetett velük kommunikálni, aztán meg kiderült, hogy ami van raktáron, az nincs is raktáron (sajnos ez magyar webshopoknál tipikus - tisztelet a kevés kivételnek). Azért végül megoldódott a dolog.
Altengernagy!
"a T-90 már egy ideje piacon van, és nem drága" Ki gyártja és mennyibe kerül?
juge75 152005 2011. november 15. 09:15
Konkrétan: Zis-151 kerék szett "Tyúklábmintás" gumival, Gaz-66 kerék szett (korai és késői).
Altengernagy 152004 2011. november 15. 09:09
Igen még emlékszem, utánanézek megint. sajnos a boltban nem voltak ilyenek a multkor.
juge75 152003 2011. november 15. 09:07
Orosz, vagy Ukrán gyártók termékei közül is tudnál be hozni?
Konkrétan a Oruzsejnyik-The Armourer-Fegyverkovács készleteiből kellene...
