| Bubu | Adatlap | 254524 | 2010. május 24. 21:07 | ![]() | |||||||||||||
Engem is meglephetne vele!:) Előzmény: (254522) orcsa 2010. május 24. 18:00 | |||||||||||||||||
| Lompi | Adatlap | 254523 | 2010. május 24. 19:46 | ![]() | |||||||||||||
| orcsa | Adatlap | 254522 | 2010. május 24. 18:00 | ![]() | |||||||||||||
| Indiana73 | Adatlap | 254520 | 2010. május 24. 13:39 | ![]() | |||||||||||||
| romeo | Adatlap | 254519 | 2010. május 24. 09:23 | ![]() | |||||||||||||
| Ronin | Adatlap | 254518 | 2010. május 23. 22:53 | ![]() | |||||||||||||
| rohamkukac | Adatlap | 254517 | 2010. május 22. 20:06 | ![]() | |||||||||||||
Ezt nem tudtam:S | |||||||||||||||||
| Levix | Adatlap | 254516 | 2010. május 22. 17:36 | ![]() | |||||||||||||
Nem vicces. A pilóta meghalt. Video: Russia launches investigation into Sea of Japan Mil Mi-14 crash An investigation has begun into the cause of a crash into the Sea of Japan by a Russian Mil Mi-14 Haze that killed the Russian pilot during a emergency simulation excercise. The military-operated Mi-14, an amphibious version of the Mi-8 Hip twin engined helicopter, was attempting a take-off from water during a joint emergency simulation excercise with the Japanese coast guard. The helicopter was carrying 13 people including two crew when it hit the water on take-off after reportedly suffering an engine failure. The inicident happened off the island of Sakhalin, north of Japan's Hokkaido island yesterday. Mi-14 sea crash W445 The Haze ploughed into a big swell as it attempted to power up with one engine inoperable, according to local reports. The helicopter had not gained any height after taking off when, it is thought, its engine failed. The helicopter fell back into the water. Its nose tipped forward into the swell. The tips of the rotors clipped the water and the helicopter toppled over, disintegrating on the surface. Russian news agency Itar-Tass says only 12 passengers survived the incident. The rescued passengers were evacuated to the port of Korsakov. The Russian transport prosecutor's office has launched criminal proceedings and is working on the assumption that the crash was caused by a technical fault in the Mi-14 or the Klimov TV3-117M 1,455kW (1,950shp) powerplants. The internet discussion site Professional Pilots' Rumour Network is hosting a debate on the cause of the crash, contributed to by several former North Sea helicopter pilots. The helicopter was part of Russo-Japanese exercises to simulate oil spill retention and search and rescue activities in the event of accidents on the oil and gas drilling platforms being constructed in the Aniva Gulf that divides the two countries. The Haze has a different landing gear to the Hip, with the aft wheels retracting into the boat-like fuselage, with the front gear folding forward into the fuselage outside the hull. | |||||||||||||||||
| juge75 | Adatlap | 254515 | 2010. május 22. 14:25 | ![]() | |||||||||||||
| rohamkukac | Adatlap | 254514 | 2010. május 21. 22:12 | ![]() | |||||||||||||
| elmo | Adatlap | 254513 | 2010. május 21. 00:19 | ![]() | |||||||||||||
Egy csésze teát, talán úgy 5 óra magasságában? | |||||||||||||||||
| lucky | Adatlap | 254512 | 2010. május 20. 17:56 | ![]() | |||||||||||||
miután minden " sz..rt" hozzájuk vágtak már csak a csésze hiányzott hozzá...:) | |||||||||||||||||
| rohamkukac | Adatlap | 254511 | 2010. május 20. 16:06 | ![]() | |||||||||||||
| juge75 | Adatlap | 254510 | 2010. május 20. 13:46 | ![]() | |||||||||||||
| rod666 | Adatlap | 254509 | 2010. május 20. 13:29 | ![]() | |||||||||||||
Sziasztok! A WC-csésze a Vietnamra ledobtt 6 milliomodik font bomba ledobásának "emlékére" került a Skyraider szárnya alá. A bevetést repülő gép a VA-25 (Fist Of The Fleet) századhoz tartozó Paper Tiger-II gép volt. A pilóta Clint Johnson volt, aki ebben az évben lelőtt egy MiG-17-et. | |||||||||||||||||
| juge75 | Adatlap | 254508 | 2010. május 20. 12:15 | ![]() | |||||||||||||
Talán 9.3x57 Mauser 1913? Minden esetre a gyutacs nincs elműködve. | |||||||||||||||||
| Sanjurjo | Adatlap | 254507 | 2010. május 20. 09:41 | ![]() | |||||||||||||
Sziasztok! Szia Rohamkukac, ha Skyraider fegyverfüggesztőjére akasztott WC csészére gondolsz, az tényleg, egy "csodafegyver" volt, amit "bevetettek" Vietnámban. Az egyik régebbi makett újságban írtak róla, az egész projekt lényege annyi volt, hogy a haditengerészet be akarta bizonyítani, az A 1 Skyraider tényleg, bármit elbír a fegyvertartóin, hogy ez, kit és mennyire érdekelt (különösen a vietkongok közül) vagy hogy használt, avagy új csészét használtak-e arról már nem szól a fáma. Szerintem nem is fontos, mert az egész csak újabb bizonyítéka snnak, hogy Amerika a korlátlan lehetőségek hazája, de pont ezért a korlátlan hülyeségeké is. Megjegyzem, én sohasem láttam fotót erről, és csak egy nagyvárosi legendának tartottam, sőt, még most se vagyok biztos benne, nem-e csak valami fotó retus az egész. Ja és slussz poén, hogy az újság, egy 1/72 A 1 Skyraider makett tesztjének apropójából írt erről, ahol a pihent agyú makettgyár, (nem tudom melyik talán Hasegawa, ha egyáltalán kiadott Skyraidert) a fegyverek kereteire állítólag ráöntötte ezt a "csodafegyvert" is, bár talán nem is rossz ötlet, egy 1/72-es fürdőszoba diorámához, talán nem is jönne rosszul egy WC csésze makett:) | |||||||||||||||||
| joci232 | Adatlap | 254503 | 2010. május 19. 14:29 | ![]() | |||||||||||||
| HUJBI | Adatlap | 254502 | 2010. május 18. 22:31 | ![]() | |||||||||||||
a holland psziposzosnak tényleg ilyen a felnije. | |||||||||||||||||
| búza | Adatlap | 254501 | 2010. május 18. 21:56 | ![]() | |||||||||||||
Tényleg tiszta életveszély!:-))) De legalább sisak van rajtuk! | |||||||||||||||||
| Wrecker | Adatlap | 254500 | 2010. május 18. 21:40 | ![]() | |||||||||||||
Szia Sennás! Persze, hogy kell ! E-mail címem az adatlapomon. | |||||||||||||||||
| Gaben | Adatlap | 254499 | 2010. május 18. 17:56 | ![]() | |||||||||||||
Na ezt a sütkérezést látná a munkavédelmis. Tiszta életveszéj. | |||||||||||||||||
| Sennás | Adatlap | 254497 | 2010. május 18. 17:14 | ![]() | |||||||||||||
Szeva Wrecker!Elviszem a haverhoz neki van szkennere majd úgy lesz a tuti!Vagy ide felteszem ha még kell, vagy magánban elküldöm írj egy címet. | |||||||||||||||||
| rohamkukac | Adatlap | 254496 | 2010. május 18. 16:51 | ![]() | |||||||||||||
| Wrecker | Adatlap | 254495 | 2010. május 18. 16:49 | ![]() | |||||||||||||
Szia Sennás ! Szerintem próbáld meg természetes fényben vaku nélkül. Akkor jól kijönnek az eredeti színek. | |||||||||||||||||
| rohamkukac | Adatlap | 254494 | 2010. május 18. 15:54 | ![]() | |||||||||||||
A 34-es képen a "csodafegyver" látható?:) | |||||||||||||||||
| rohamkukac | Adatlap | 254493 | 2010. május 18. 15:48 | ![]() | |||||||||||||
Azért ez már gáz...:S | |||||||||||||||||
| romeo | Adatlap | 254492 | 2010. május 18. 12:35 | ![]() | |||||||||||||
| juge75 | Adatlap | 254491 | 2010. május 18. 12:16 | ![]() | |||||||||||||
"Tűzerőt maximumra, cél a tejbepapifejlesztő!" | |||||||||||||||||
| Jimobá | Adatlap | 254490 | 2010. május 18. 09:59 | ![]() | |||||||||||||
Látszik a hátérben, hogy többi is tréleren van. Tehát úgy borulhatott. "Szép" kis baleset lehetett. Ha már a folyópartnál tartunk... Most olvastam valahol, hogy pár éve Irakban egy Abrams belezuhant egy nagy folyóba egy hídról, és az egész személyzet belefulladt. Csúnya halál... Üdv :( | |||||||||||||||||
| juge75 | Adatlap | 254488 | 2010. május 18. 07:04 | ![]() | |||||||||||||
Már lentebb meg lett írva a tuti, trélerre felhajtás közben lecsúszott, lehet a szalagfék beállt. | |||||||||||||||||
| HUJBI | Adatlap | 254487 | 2010. május 18. 06:48 | ![]() | |||||||||||||
| Rambo | Adatlap | 254486 | 2010. május 18. 00:23 | ![]() | |||||||||||||
Szergej megint többet ivott a kelleténél :D | |||||||||||||||||
| vlevi | Adatlap | 254485 | 2010. május 18. 00:03 | ![]() | |||||||||||||
Mondjuk, ha seggrészegen próbál leugratni az őt szállító teherautóról, és kicsit féloldalasra sikerül a manőver. | |||||||||||||||||
| Sennás | Adatlap | 254484 | 2010. május 17. 23:47 | ![]() | |||||||||||||
| KapusiZoli | Adatlap | 254483 | 2010. május 17. 23:29 | ![]() | |||||||||||||
Hello!Nekem egyik ismerősöm mondta, hogy azokat a Hummereket az amcsik vágták ketté, annak idején akartak venni belőlük, hogy majd összehegesztik, de nem lett belőle semmi. ü | |||||||||||||||||
| Sennás | Adatlap | 254482 | 2010. május 17. 23:23 | ![]() | |||||||||||||
| Sennás | Adatlap | 254481 | 2010. május 17. 23:02 | ![]() | |||||||||||||
Csináltam vakus meg v.nélküli képeket hát melyik a jobb? | |||||||||||||||||
| Wrecker | Adatlap | 254480 | 2010. május 17. 22:55 | ![]() | |||||||||||||
Előre is köszönöm ! | |||||||||||||||||
| Sennás | Adatlap | 254479 | 2010. május 17. 22:47 | ![]() | |||||||||||||
Megkeresem de csak papírkép, lefotozom és utána felteszem. | |||||||||||||||||
| Wrecker | Adatlap | 254478 | 2010. május 17. 22:38 | ![]() | |||||||||||||
Tudnál felrakni képeket a roncs Humveek-ról ? | |||||||||||||||||
| Sennás | Adatlap | 254477 | 2010. május 17. 21:49 | ![]() | |||||||||||||
2001-s Dombóvári Vasutasnapon voltunk,az állomás mellet volt{van}MÉH telep,ott fotóztam ilyen törött humveeket egymás hegyén hátán persze hogy 5 perc alatt elzavartak.Gondolom egy köpésre van Taszár az ottani Yankee Boys amortizálták le őket? | |||||||||||||||||
| Ronin | Adatlap | 254476 | 2010. május 17. 21:35 | ![]() | |||||||||||||
| Sennás | Adatlap | 254475 | 2010. május 17. 21:10 | ![]() | |||||||||||||
Sziasztok!Pár érdekes Hummeres kép.Unatkozó,kreatív katonák{a felrobbantottra nem vonatkozik}illetve 3-4 kép érdekelne tényleg volt JOBB kormányos változat? | |||||||||||||||||
| sanyi | Adatlap | 254474 | 2010. május 17. 19:27 | ![]() | |||||||||||||
Kérünk még képeket!:) | |||||||||||||||||
| rohamkukac | Adatlap | 254473 | 2010. május 17. 18:32 | ![]() | |||||||||||||
| atis76 | Adatlap | 254472 | 2010. május 17. 11:04 | ![]() | |||||||||||||
Üdv! Kitartás miskolciak és mindenhol ahol problémát okozott az időjárás! Nálunk Tapolcán inkább az erős szél okozott károkat. Rendesen átrendezte a kerteket, udvarokat. Atis | |||||||||||||||||
| rohamkukac | Adatlap | 254471 | 2010. május 16. 23:22 | ![]() | |||||||||||||
| Sennás | Adatlap | 254470 | 2010. május 15. 21:41 | ![]() | |||||||||||||
| Jimbobá | Adatlap | 254469 | 2010. május 15. 19:36 | ![]() | |||||||||||||
Jaja, az olimpiára készültek. Ez a cucc a sok gyaloglás helyébe kellett gondolom, biztos járőröztek ezerrel a városban. És ha ez a kétkerekű izé olyan stabil mint a nyugati társai, akkor menet közben jobban lehet lőni, mint lábon. Persze nem ez volt a fő profil, de ezt is gyakorolták. Talán a hírekben is volt. Üdv Itt is a cikk (plusz a képed) www.mailonsunday.co.uk/news/article-1031298/Wheel-scary-Chinese-anti-terror-police-practise-killing-drills-scooters.html | |||||||||||||||||
