MiG-21
181., 182., 183., 184., 185., 186., 187., 188., 189., 190., 191.
Miggyuri 368508 2008. február 25. 04:56
Bitte auf Ungarisch! Pa vengerszi pázsáluszta!
sainz 368507 2008. február 24. 23:58
Haaat ez ???
Hihetetlen vagy megsem?
Recently, I've heard probably the craziest "that pilot and his mission..." story ever...
The older ones between us are going to remember, that in the 1970s and 1990s, British Airways used to fly Concorde over Africa. To be sincere, this is so long ago, that even I can only barely recall all the details, or what were the destignation this line connected.
Now, in the later years, there was a detour-route introduced to avoid complaints because of the Mach 2 shock-cone the plane was pulling behind it, causing complaints from the local population. But, at earlier times, the original route took these roughly over Nigeria and several other countries due east...
And, as most of us know, Nigeria used to have two squadrons equipped with MiG-21s...
Surely, we all come to "specific" brilliant ideas time and again. And so it happened that there was "that" Squadron-Commander of a specific Nigerian Air Force MiG-21-unit, who once wanted to see if he can intercept a Concorde. To keep the long story short, without any authorisation from higher authorities, but with help of a sellected crew of one of available ground-based radar stations, and sitting in a carefully pre-inspected MiG-21 (armed with two R-13M missiles and carrying three drop tanks), this officer decided to give it a try...
Some here might be surprised to hear that he "almost" made it: the ground radar station crew was working well, so the MiG ended within the max engagement envelope of the Concorde. Surely, the MiG-21MF wouldn't go as high or as fast as Concorde was flying, so this "meeting" was of a very short duration. Besides, the smart officer in question almost run his plane out of fuel while attempting to catch the Mach-2-airliner...
But - and now comes the best part: while keeping an eye on his fuel status, the redoutable officer in question acquired that Concorde, and fired two R-13Ms!
Luckily for non-suspecting passengers and the crew of the supersonic delta high above him (these have never even noticed the MiG or his missiles), both R-13s run out of steam before reaching their target - even if the source of this story commented that it was actually "quite a close shave".
BTW, the source in question is really reliable: this is no "urban legend". It happened for real.
cseka76 368506 2008. február 24. 17:25
Köszi Szabi77,ez nekem is meg van!
Valószínű,hogy ilyen festéssel készítem a gépet.
cseka76
Szabi77 368505 2008. február 24. 16:59
21Fgdr2
21Fgdr2
Cseka76!
Lehet hogy már láttad itt egy terepszínű F13-as!
Szabi77
cseka76 368504 2008. február 24. 12:23
makettes 368503 2008. február 24. 12:03
Szia Sainz!
Mi a helyzet a készülő könyveddel?
üdv. makettes
zoli1989 368502 2008. február 24. 11:46
623
623
623-n
623-n
f-13622
f-13622
F1301
F1301
F13.03
F13.03
F13.02
F13.02
scheindhs
scheindhs
Én ezeket találtam:
sainz 368501 2008. február 24. 10:58
21s
21s
52xx
52xx
5210 a
5210 a
5210
5210
pilot a
pilot a
s
s
ooops..
sainz 368500 2008. február 24. 10:55
Nekem ezek tenger-kamonak tunnek(de lehet h jol alcaz a dzsungel felett is).
A 21-es pilotan mintha mentomelleny lenne, de a szuhoj pilotakon egyertelmu.
cseka76 368499 2008. február 24. 10:50
Köszi szépen ezeket is!
cseka76
sainz 368498 2008. február 24. 10:41
335
335
605
605
622 a
622 a
639
639
677
677
688
688
744
744
Nekem ennyit sikerult osszekaparni a neten(de mar regen nem vadasztam, lehet, hogy vannak ujabbak is), nem igazan hasznalhatoak makettezo szemmel.
A DHL konyvben van meg par szines foto.
sainz 368497 2008. február 24. 10:27
Es ha megnezzuk azt a keves fotot ami napvilagot latott viet MiG-21bis-esekrol(MF-et kivontak 2000 tavaszan), vagy a gyari teflonszurke vagy kulonbozo kek terepfestest viselnek.Ez egyertelmuen a tenger feletti feladatokra utal.
A viet Szu-22-esek pedig nemreg lettek modernizalva, elsodleges feladatuk a hajok elleni harc, rendszeresen lovoldoznek hajoroncsokra UB-val es kH-23-al.
cseka76 368496 2008. február 24. 10:19
sainz!
Tudnál még esetleg néhány terepszínű NDK-s 21 F13 képet?
cseka76
Hind 368495 2008. február 24. 10:14
Söt,a katapultülésben lévő túlélőkészlet is annak fügvényében van összeállítva,hogy hol operál a repcsi.Mert ugye a horgászkészlet,és a gumicsónak szárazföldre nem annyira okés:
sainz 368494 2008. február 24. 10:02
Haaat...sztem a vietamiak szinte mindig mentomellenyben repultek(nek).
Az egesz orszag relative keskeny es hosszu tengerparttal rendelkezik.
A tamadok joresze pedig anyahajokrol erkezett-tavozott, nagyon sok legiharc, de meg lerakkal leloves is a tenger felett tortent.
Szoval a mentomelleny nem kizaro ok.
migi 368493 2008. február 24. 09:53
Most már biztos vagyok benne hogy igy történt , mit keresne mentőmellény a VDK pilótákon légiriadónál .
cseka76 368492 2008. február 24. 07:07
flagon,légyszi írj egy email címet,mert nem találom!
cseka76
sainz 368491 2008. február 23. 22:53
21-1
21-1
Egy kis Afrika, napjainkban:
sainz 368490 2008. február 23. 22:51
Elkepzelheto hogy beletettek a filmbe egy reszletet.
Nem lehet egyszeru eredeti vietnami filmfelveteleket talalni(venni) egy ilyen filmhez.
migi 368489 2008. február 23. 22:25
Igen lehet, de mit kerestek ezek akkor Vietnámban ? mikor kezdték ezeket gyártani? vagy a filmrészlet nem ott készült csak bevágás volt ugymond 21-es db.db sárgák sárgák .
migi 368488 2008. február 23. 22:17
Úgy nyilt mint a 23 kabinteteje
sainz 368487 2008. február 23. 22:16
Valoszinuleg egy csajniz J-7-es volt az:
www.fas.org/man/dod-101/sys/ac/row/mig-21.htm
migi 368486 2008. február 23. 22:09
Igen Laci ezt tudom de ez hátulról felfelé nyilt vagyis a forgáspont hátul volt .megpróbálok a filmből képet késziteni valahogy .
Rumcájsz 368485 2008. február 23. 22:01
Mi ebben a megdöbbentő, a 21F és PF és első szériás PFM tipusoknak a kabinteteje hátulról előre-felfelé nyilt, magyarán a dekk bekötési-forgási csomópontja elöl volt, és két süritett-levegős munkahenger nyitotta fel.
mig23papa 368484 2008. február 23. 21:01
Heló Laci
Ebből is látható hogy a Mig 21 lehetőségei máig is kimeríthetetlenek
csekát már értem :-)
migi 368483 2008. február 23. 20:45
Szia Laci
Nem 76 cd hanem a kollega nick neve cseka 76
Néztem egy Vietnámi kisfilmet Mig-21-sekről és megdöbbenve láttam egy olyan gépet aminek a kabin teteje hátulról nyilik felfele .
üdv: migi
mig23papa 368482 2008. február 23. 19:44
flagon
megkérdezhetem mi van azon a 76 CD-n?
cseka76 368481 2008. február 23. 19:38
flagon
Küld el légyszi!
cseka76 368480 2008. február 23. 19:37
flagon 368479 2008. február 23. 19:20
cseka 76 CD-van elküldjem?
sainz 368478 2008. február 23. 19:13
21
21
A terepszinu 21F-13 erdekes makett lehet:
cseka76 368477 2008. február 23. 18:55
Szia flagon!
Igen,érdekel! Esetleg neked meg van?
cseka76
flagon 368475 2008. február 23. 18:42
cseka76 DHS kiadvány Mig-21 F-13 44oldal NDK-s gépek német nyelvü érdekel?
cseka76 368474 2008. február 23. 16:42
NDK-s Mig-21 F13 Fishbedek-ről keresgélek képeket. Ha van valakinek ilyen témájú anyaga,légyszi segítsen!
Előre is köszi!
cseka76
cseka76@freemail.hu
mig23papa 368473 2008. február 23. 15:12
MIG_21_9510
MIG_21_9510
MIG_21_9510_LHPA_ASZ005
No és amikor még repült is a 9510-es
SIG 368472 2008. február 23. 14:47
beolvasás0009
beolvasás0009
beolvasás0010
beolvasás0010
beolvasás0011
beolvasás0011
beolvasás0012
beolvasás0012
beolvasás0013
beolvasás0013
beolvasás0014
beolvasás0014
beolvasás0015
beolvasás0015
beolvasás0016
beolvasás0016
Halihó !
Itt vannak a beigért képek a 9510-es oldalszámú Mig-ről. Feltettem még párat ami nem az, de a részletek miatt esetleg jól jöhet. Az uccsó kép pedig a kedvencem, pusztán a típus kedvelőinek. Ha kell még speckó festés a pápai cuccokról, van kép a 6115-ös Jubileumiról vagy a "madárfejes" 48-ról. Sikíts ha kell még valami.
Üdv...
sainz 368471 2008. február 22. 23:07
Mail ment.
Tokol valszeg stimmel, bar hianyos:
MiG-21PFM -1972
MiG-21CM(T)1972-82
MiG-21CMT 1072-82
MiG-21bis 1982-87
Rumcájsz 368470 2008. február 22. 22:57
Nem igazán értem, hiszen akárhogy olvasom, vagy SzMT-ről, vagy SzM-ről van szó, SzT
itt sem szerepel.Ebből a jelzésből nekem inkább az jön ki, hogy SzM-ből alakitottak át
SzMT-re, esetleg vegyes volt az ezred gépállománya. Persze igy sem az igazi, legalábbis Tököl esetében, mert itt a vegyes állomány SzMT-ből és SzT-ből állt, és egyik sem téveszthető össze az SzM-el, aminek még kisebb a gerinctartálya. Minél több az új info, annál inkább zavaros számomra.
sainz 368469 2008. február 22. 22:18
Bingooo!
Megvan.
Azoknal az orosz ezredeknel, ahol modositottak az SzMT-ket, igy irja az orosz lista:
CM(T)
159.gv.iap. Kluczevo
515.iap. Tokol
582.iap. Chojna
E szerint csak a Lengyelorszagban es nalunk allomasozo SzMT ezredeknel hajtottak vegre ezt az atalakitast.
sainz 368468 2008. február 22. 22:08
Rumcajsz!
Kuldj egy emilcimet(itt vmiert nem tudom megnezni). atkuldom a listakat, szerintem nem ugyanabol dolgozunk, ezeken amik nalam vannak, mar jopar eve izzad nehany orosz.
Elvileg pontosak.
sainz10@gmail.com
Esetleg meg a lemezosztas segithet eldonteni, az is kulonbozik a bis - MF-nel.
notarius 368467 2008. február 22. 21:55
Közben megjött egy, köszönöm.
Rumcájsz 368466 2008. február 22. 21:54
Az oldalnézeti fotó szerint /pilóták mögött a háttérben/ egyértelmüen MF/SzM, itt jól kivehető, hogy a gerincvonal nem ér el a függőleges vezérsik főtartójáig, tehát
nem lehet bisz/SzT változat. A nálam lévő források szerint sem gyártottak SzT-válto-
zatot, csak átépitettek, részben az alakulatok müszaki részlegeinél, részben a nagyjavitást végző üzemekben, tehát gyártási listán nem is szerepelhet. Az alakulatok
tipuslistájáról való hiányzásra viszont én sem tudok magyarázatot, hiszen ez az SzMT gépállomány 6-8 vadászezredre való mennyiség, még ha nem is épitették át a teljes flottát, akkor se tünhettek el a semmiben.
Hind 368465 2008. február 22. 21:54
Elment magánba!
De van még egy közeli is,azt keresem a leginkább!
notarius 368464 2008. február 22. 21:43
Nekem is xarakszik napok óta.
Melyik az a rotorcraft?
sainz 368463 2008. február 22. 21:30
Sajna pont a fuggoleges vezersik tove nem latszik, ebbol a szogbol csaloka, nem igazan lehet eldonteni bis v MF/SM...akik kozelrol lattak, eskusznek ra h 96-os.
Az SzT nalam tovabbra is talany, sem a gyartasi listan(nem konyvekbol, ujsagokbol valo) sem az alakulatok tipuslistajan nem szerepel sehol...
Viszont ahoz tul sokan emlegetik, hogy kacsa legyen.
Rumcájsz 368462 2008. február 22. 20:39
Puff neki, most nézem az oldalnézeti képet, azon meg MF, vagyis 96-os látható. Hát ha ez a két gép azonos, hát akkor ennyit az éleslátásomról, vagyis hiába van dupla szemem,
attól nem látok jobban.
Rumcájsz 368461 2008. február 22. 20:38
Hind 368460 2008. február 22. 20:29
Notarius!!
Nem megy a freemailom!!
A rotorcraft rovatba beteszem a képeket!
Rumcájsz 368459 2008. február 22. 20:28
Szerintem ez inkább bisz-nek /75/ néz ki, elég testes a gerinctartály, de a másik kigazitásod szerint lehet SzT változat is , a pitot tartórúdjába meg olyan pitot-csövet
szereltek a kirabolt helyett, amit éppen találtak, én már söprünyelet is láttam ilyen kiállitott gépen /mondjuk az MiG-19 volt/. A másik téma: sajnos fejből irtam a 1524 sz. szövegemet, igy kevertem az MT és az SzT változatokat, a "szentirás" szerint is neked van igazad, tehát a kisebb gerinctartállyal átépitett SzMT új jelzése lett SzT, ami külsőre majdnem azonos a bisz-el /már csak azt kéne tudni, az a bizonyos MT vajon hogy néz ki, melyikkel egyezik meg külsőre?/
Az összképet egyébként még a kinai gyértmányok is bonyolitják.
Rumcájsz 368458 2008. február 22. 20:25
