| 21., | 22., | 23. |
| ati27 | Adatlap | 388149 | 2006. március 9. 16:00 | ![]() | |
Télleg? Fotó van? | |||||
| pilotka | Adatlap | 388148 | 2006. március 9. 15:31 | ![]() | |
Skacok! 1 Gripen már itthon van, 15-én mennek ki a pilcsik vissza értük, és a 20-val kezdődő héten 5 db-ot hoznak haza | |||||
| Tibcsi | Adatlap | 388147 | 2006. március 9. 13:02 | ![]() | |
És hová lett a Puma jelvény? És a Kecskeméti ezredjelvény? | |||||
| ati27 | Adatlap | 388146 | 2006. március 9. 11:48 | ![]() | |
Hi All! Néztam a matricát... A felségjel az eredetiben nem lovis? | |||||
| Farkaskoma | Adatlap | 388145 | 2006. március 9. 10:36 | ![]() | |
TwoBobs 1/48 &1/72 Gripen A/B/C/D Markings for Sweden and Hungary Product # 48-118 and 1/72 # TBA New Product info from Twobobs Aviation Graphics on Mar 7 2006 Here's a sneak peek of the Gripen sheet that you've all of you have been waiting for. References were provided to us by Emil Lindberg who is a Gripen maintainer in Sweden. This guy provided us some real "over the top" references and I'm here to tell you, this is one super accurate sheet. What he did to capture this jet is incredible. You'll be able to build ANY A/B/C/D model Gripen from Sweden with this sheet. There are also markings on the sheet for a Hungarian machine. Full stencil data is included in both Swedish and English!! Yikes!! The image below represents a 1/48th scale sheet. We will also release a 1/72nd scale sheet at the same time. We'll piggyback right on top of this one with four sheets that are VERY close to being done also. Two VMFAT-101 adversary sheets as well as two sheets for VFA-131!! Bob aircraftresourcecenter.com/IndNews1/001-100/35/35.htm | |||||
| Akos | Adatlap | 388144 | 2006. március 8. 10:17 | ![]() | |
Nekem az Italeri 1:48-asa van meg, de nem tudtam eddig HAD matricát szerezni hozzá. A makett egyébként elég jó (sokkal jobb, mint a 72-es), de nem árt hozzá az Eduard maratása. És van hozzá cseh matrica is, bár ez nekünk nem sokat számít... | |||||
| ati27 | Adatlap | 388143 | 2006. március 7. 21:55 | ![]() | |
Ja március!:) Elírtam... | |||||
| Bombraider | Adatlap | 388142 | 2006. március 7. 20:11 | ![]() | |
Öcsém Március:) | |||||
| ati27 | Adatlap | 388141 | 2006. március 7. 20:08 | ![]() | |
Elvileg május végén jönnek... :) | |||||
| Szunyog | Adatlap | 388140 | 2006. február 27. 21:25 | ![]() | |
Sziasztok! Néhány kép az Italeri készletéről,remélem segít. (Bocs a minőségért!) Van magyar matrica is hozzá, ha kell azt is le fényképezhetem. (TOFF BT.) Üdv:Szunyog | |||||
| Tibcsi | Adatlap | 388139 | 2006. február 27. 19:07 | ![]() | |
Nekem a Revell van meg, tényleg nem rossz. Ha a két fő hibáját kijavítjuk, zárt kabinnal elég jó. A két hiba: a két kisebb gerincantenna túl nagy, és a katapultülést is érdemes kicserélni/feljavítani. Az A és a C között szerintem csak a légi utántöltő csonk a külső különbség. Meg azt hiszem, a főfutó kerék valamivel nagyobb a C-n, mert az nehezebb. | |||||
| ati27 | Adatlap | 388138 | 2006. február 27. 17:57 | ![]() | |
állítólag az italeri nem olyan rossz! De a revell dobozban is az italeri van és állítólag az italeri matricái jobbak mint e revell! Kicsit furcsállom!:) | |||||
| Bundesign | Adatlap | 388137 | 2006. február 27. 09:18 | ![]() | |
hy! az italeri 1:72 kétszemélyes gépét nézegettem a multkor, elég gyenge kidolgozottságú szerintem, de vannak jó részletei,gravírozott panelvonalak, meg stb .. alapnak megfelel :) üdv: bundesign | |||||
| migfun | Adatlap | 388136 | 2006. február 27. 05:16 | ![]() | |
Amennyire én tudom, a geometriai méretek nem változtak, ezért lehet az EBS-HU-t is a régi és az új gépek fődarabjaiból összetákolni. Látványos lehet az új NATO-szabvány fegyvertartó a dél-afrikai és a magyar gépeken, ez eltér az eredetitől, de a régi van a svéd és a cseh gépeken. | |||||
| ati27 | Adatlap | 388135 | 2006. február 25. 20:36 | ![]() | |
Esetleg... Tudja valaki, hogy a "szimpla" A változat, és a block c között van e valami nagyon látványos külömbség? Értem ez alatt ges adatoka:hossz, fesztáv, nagyobb geometriai változások... | |||||
| MrChef | Adatlap | 388134 | 2006. február 23. 22:10 | ![]() | |
Én készülök venni egyet! Csak előtte még építtetek a Bugatti Veyron-omnak egy hangárt, és abba tolom majd be a Gripókámat! Remélem a svédek hamar legyártják nekem, mert kiverem a balhét, ha túl sokáig pepecselnek rajta!:-)) | |||||
| ati27 | Adatlap | 388133 | 2006. február 23. 21:55 | ![]() | |
Gondoltam van helye egy ilyen topicnak! Nemsokára itt vannak a magyar gripenek! Másrészt csordogálnak a makettváltozatok: Italeri/revell 1/72, italeri,MPM 1/48-ban, már látni a magyar festéssel üzemelő gépeket is! Tehát! Valaki már találkozott ezekkel a készletekkel/építette? Várom a tapasztalatokat-véleményeket, "érzéseket" mind a makettváltozatokról, és magáról a vasról is! | |||||
